Home > Maintenance & Modifications > Failed alternator
gogsy1956
Failed alternator
Looks as if my alternator has failed,, battery just died overnight after ok the day before. My normally reliable jump starter wouldn't even look at it. Bit the bullet and got the aa out, even his portable unit was no good,,,, resorted to the back up unit,,,, ie his van and success. Charging rate seemed to be erratic at times so only being a few minutes from home he put a 20min boost into my battery to allow me to get home.
I know the preferred choice of alternator is the denso unit,, but whilst looking last I came across rebuilt units. Has anyone ever had any luck with these,, or are they only a short term fix. 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #628934 Thu Dec 08 2022 7:39am
Disco_Mikey
New Denso item isn't that expensive. Stick with what you know is good Thumbs Up
Post #628942 Thu Dec 08 2022 12:41pm
gogsy1956
Yep,,, was thinking down those lines Thumbs Up 2010 RRS, TDV8
22" overfinch
Post #628946 Thu Dec 08 2022 1:20pm
Crs
England 2013 Range Rover Sport Supercharged Autobiography Firenze Red
Had exactly the same problem a few days ago, I had to have it recovered along the roadside, everything went dead just before every warning light came on, the recovery driver tried to boost start it to get it on the lorry and it was just draining his booster, had to winch it on.
Post #628964 Thu Dec 08 2022 9:28pm
gogsy1956
Hi Carl,,,, so what did the problem turn out to be?? 2010 RRS, TDV8
22" overfinch
Post #628981 Fri Dec 09 2022 6:24pm
Crs
My problem was a an Alternator fail , the battery completely emptied itself trying to keep things going, had to have a new battery as well as that would not take a charge afterwards, plus diagnostics to clear all the warning symbols. That’s my Christmas present this year.
Chris.
Post #628982 Fri Dec 09 2022 7:13pm
Montipora
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Santorini Black
Looks like mines just gone today as well. Charging system error message, only got 12.2v across battery terminals with engine running. Only had car 3 weeks! Covered by warranty though luckily
Post #628983 Fri Dec 09 2022 7:24pm
Crs
Lucky for you that’s covered, my bill for was just over £800
Post #628984 Fri Dec 09 2022 8:32pm
Covered by the consumer protection laws actually. The warranty is a red herring used by some used car salesmen to fob people off. Either way, you're sorted. Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #629027 Sun Dec 11 2022 10:47pm
Montipora
To be fair the dealer has been good, recovered the car today so hopefully will be fixed tomorrow
Post #629029 Sun Dec 11 2022 10:59pm
gogsy1956
So you actually got a charging error message? No warning on mine at all as far as I know as I wasn't driving it at the time. I have since charged the battery overnight on my ctek and had the car running and it appears to be charging ok,, seems to be steady at the 14.8V mark. I think I need to have the battery tested even though it's less than 3 years old. Wondering whether to to bite the bullet and put a new alternator in anyway as it is the original,, at least I'll be sure that's going to be ok. Everything's at a stop at the moment as I'm away for a couple of days. 2010 RRS, TDV8
22" overfinch
Post #629034 Mon Dec 12 2022 11:25am
Crs
Yes I was driving along when the battery light came on followed by pretty much every warning light, the engine died leaving us stranded on the road, we managed to open our doors but the others locked including the rear tailgate where the towing hook is, the recovery drivers jumper could not put enough power into the system to do anything, he had to put a strap on it and winch onto the lorry. I have read of a very disturbing situation where the Range Rover engine caught fire and the doors would not open, luckily they had the sun roof open to get out, JLR were asked to comment on that but did not.
Post #629035 Mon Dec 12 2022 12:18pm
gogsy1956
Thanks for the info Chris,, just trying to gather as much as I can,, I couldn't believe that no warnings surfaced at all on mine,,, it was just the next day that problems arose when trying to start it first thing. Battery was properly flat by the time I got there and tested it,, less than 11v.and maybe the erratic charging was the alternator trying to charge a severely depleted battery. Now that the battery is fully charged the charging rate seems steady,,,, but there's always going to be a niggle in the back of my mind if there is a problem waiting to surface again. Need a battery health check to put my mind at ease I think. 2010 RRS, TDV8
22" overfinch
Post #629036 Mon Dec 12 2022 12:46pm
