![]() | Home > Maintenance & Modifications > Failed alternator |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4452 ![]() ![]() ![]() |
New Denso item isn't that expensive. Stick with what you know is good |
Yep,,, was thinking down those lines |
Crs Member Since: 04 Sep 2022 Location: Hampshire Posts: 82 ![]() ![]() ![]() |
Had exactly the same problem a few days ago, I had to have it recovered along the roadside, everything went dead just before every warning light came on, the recovery driver tried to boost start it to get it on the lorry and it was just draining his booster, had to winch it on. |
Hi Carl,,,, so what did the problem turn out to be?? 2010 RRS, TDV8
My problem was a an Alternator fail , the battery completely emptied itself trying to keep things going, had to have a new battery as well as that would not take a charge afterwards, plus diagnostics to clear all the warning symbols. That’s my Christmas present this year.
Montipora Member Since: 05 Nov 2022 Location: Cornwall Posts: 13 ![]() ![]() ![]() |
Looks like mines just gone today as well. Charging system error message, only got 12.2v across battery terminals with engine running. Only had car 3 weeks! Covered by warranty though luckily |
Lucky for you that’s covered, my bill for was just over £800 |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9051 ![]() ![]() ![]() |
Covered by the consumer protection laws actually. The warranty is a red herring used by some used car salesmen to fob people off. Either way, you're sorted. ![]() 2008 TDV8 - it was a labour of love and is much missed |
To be fair the dealer has been good, recovered the car today so hopefully will be fixed tomorrow |
So you actually got a charging error message? No warning on mine at all as far as I know as I wasn't driving it at the time. I have since charged the battery overnight on my ctek and had the car running and it appears to be charging ok,, seems to be steady at the 14.8V mark. I think I need to have the battery tested even though it's less than 3 years old. Wondering whether to to bite the bullet and put a new alternator in anyway as it is the original,, at least I'll be sure that's going to be ok. Everything's at a stop at the moment as I'm away for a couple of days. 2010 RRS, TDV8
Yes I was driving along when the battery light came on followed by pretty much every warning light, the engine died leaving us stranded on the road, we managed to open our doors but the others locked including the rear tailgate where the towing hook is, the recovery drivers jumper could not put enough power into the system to do anything, he had to put a strap on it and winch onto the lorry. I have read of a very disturbing situation where the Range Rover engine caught fire and the doors would not open, luckily they had the sun roof open to get out, JLR were asked to comment on that but did not. |
Thanks for the info Chris,, just trying to gather as much as I can,, I couldn't believe that no warnings surfaced at all on mine,,, it was just the next day that problems arose when trying to start it first thing. Battery was properly flat by the time I got there and tested it,, less than 11v.and maybe the erratic charging was the alternator trying to charge a severely depleted battery. Now that the battery is fully charged the charging rate seems steady,,,, but there's always going to be a niggle in the back of my mind if there is a problem waiting to surface again. Need a battery health check to put my mind at ease I think. 2010 RRS, TDV8
