Home > Wheels & Tyres > Winters fitted today 2 x swollen nuts
Stevepd
I chose today to swap them over for the season. All going well rolling around and showing zero degrees. Got to the last wheel and my 22mm socket wouldn’t fit over 2 of the nuts. Went to the toolbox and got the multi sided socket and my nylon hammer. Gently tapped it on and undid the nut. Punched it out with my drift which showed how fragile these are. Repeated for the second nut and luckily I have spares.
Where’s the current go to for solids please.
Photos in my gallery if it doesn’t show.
 2006 2.7 TDV6 HSE in Cairns Blue.
Post #628916 Wed Dec 07 2022 3:38pm
Googs
Australia 2012 Range Rover Sport Supercharged Autobiography Fuji White
Well done with the removal of the swollen rusty wheel nuts Steve, i see there's a big problem here is there no solids to fit the RRS lugs? So these could be rusting on your RRS without you even knowing, so when on a terrible wind day (i hate the wind) you could get a flat tire and not be able to change out the flat hence having to call a tilt tray truck to get you to the repair shop.
Has the aftermarket lug nut being sort after?
Post #628917 Wed Dec 07 2022 4:45pm
Dave B
I too had 2 swollen nuts when I changed wheels, problem was solved once I got the wheel alignment tool.
Oh, sorry, didn't read the full story.
Dave 2010 3.6 TDV8 HSE (Gone)
2011 Discovery 4 Commercial SDV6 (Gone)
1980 OBLIC 4.0ltr Range Rover (went a long time ago)
Post #628918 Wed Dec 07 2022 5:33pm
BJH1959
Portugal 2005 Range Rover Sport TDV6 HSE Cairns Blue
Can't help as to getting the new nuts, but well done for getting the old ones off! Thumbs Up Barrie.
2017-Jan 2024: 2005 RRS 2.7TDV6. Best car I ever had - until now!
Current: 2018 Ford Ranger Wildtrak 3.2
Post #628927 Wed Dec 07 2022 7:45pm
These are what you need, but there not cheap. Laughing
https://www.wrington.co.uk/wheel-nuts-for-...oy-wheels/
Post #628928 Wed Dec 07 2022 8:30pm
