Home > General (L494) > Easy Job - unblocking opening panoramic sunroof drains L494 |
Grimble Member Since: 21 Aug 2020 Location: Staffordshire Posts: 250 |
Im sure mine are blocked as well but as I never open my windows unless to pay at a barrier, it has not been a big issue.
Mon Nov 28 2022 1:38pm |
Googs Member Since: 04 Oct 2022 Location: Greens Beach Tasmania Posts: 89 |
I doubt it fishing line will do the job but i know that grass trimming line will do it for you....it worked for me okay. |
Mon Nov 28 2022 6:37pm |
Off to my shed, I think I have a reel somewhere! Thanks! RRS HSE Dynamic SDV6 2014
Tue Nov 29 2022 11:54am |
Karlp606 Member Since: 25 Jun 2022 Location: East Yorks Posts: 216 |
Had a leaky sunroof last week with the heavy rain.
Tue Nov 29 2022 12:23pm |
RRS? Member Since: 02 Sep 2023 Location: Lincs Posts: 27 |
Gentle bump for this, and a token of my gratitude. I’ve struggled for two days from the top before I found this. Done in 5 mins! 2004 D3 HSE TDV6 2011 D4 HSE SDV6 2015 L494 RRS Autobiography SDV6 |
Fri Aug 02 2024 8:55pm |
Just a word of warning, the sunroof drains holes have a small stubby pipe that the hose connects to. This pipe is prone to corrosion, causing the rubber drain hose to become detached and water to run down the roof lining. potentially causing mayhem with electrical systems.
Mon Aug 05 2024 9:31am |
markiep1 Member Since: 28 May 2024 Location: Derbyshire Posts: 6 |
I wonder if the extended warranty would cover the electrical damage! You’d think they would have modified the pipe in its early stages once it became apparent there was a fundamental problem |
Mon Aug 05 2024 10:37am |
