Home > General (L494) > Easy Job - unblocking opening panoramic sunroof drains L494
Punkawallah
United Kingdom 2013 Range Rover Sport Supercharged Autobiography Adriatic Blue
Since I bought my L494 in Feb it’s emptied the rainwater on the roof onto my right arm through the open driver’s window on the first corner I drive around after leaving home.
The sunroof drains into the rear wheel arch on both sides. If you take off the rear quarter interior panel
On each side you can see the drain tube and can gently remove them from where they meet/exit to the exterior through the bodywork.
You can then insert an air line and - very gently at first to avoid blowing the pipe off its connector at sunroof level - blow up through the tubes and hopefully you’ll hear a satisfying pop and gush of air coming from half way along each sunroof rail.
Literally a 5 minute job.
If you have “rear climate” like I do, it’s a little more fiddly on one side but you can disconnect the fan’s exit pipe (will make sense when you look at it) and reach the tube plug behind it.
Hopefully this is helpful! 2014 L494 V8 s/c Autobiography Dynamic
Post #628629 Sun Nov 27 2022 6:52pm
Grimble
Im sure mine are blocked as well but as I never open my windows unless to pay at a barrier, it has not been a big issue.
Rather than remove trim, does anybody know how easy it would be to use a thick fishing line to do the same job? Assuming of course the entry/exit point is accessible. RRS HSE Dynamic SDV6 2014
Nemo mortalium omnibus horus sapit
Post #628652 Mon Nov 28 2022 12:38pm
Googs
Australia 2012 Range Rover Sport Supercharged Autobiography Fuji White
I doubt it fishing line will do the job but i know that grass trimming line will do it for you....it worked for me okay.
Post #628667 Mon Nov 28 2022 5:37pm
Grimble
Off to my shed, I think I have a reel somewhere! Thanks! RRS HSE Dynamic SDV6 2014
Post #628689 Tue Nov 29 2022 10:54am
Karlp606
Had a leaky sunroof last week with the heavy rain.
Found it was the rear passenger corner - you can do it from the top - you just need to pop off the black gloss plastic trim that runs along the sunroof as thats where the drains are - mine was full of leaves/seeds.
Post #628690 Tue Nov 29 2022 11:23am
RRS?
Re: Easy Job - unblocking opening panoramic sunroof drains L
Gentle bump for this, and a token of my gratitude. I’ve struggled for two days from the top before I found this. Done in 5 mins! 2004 D3 HSE TDV6
2011 D4 HSE SDV6
2015 L494 RRS Autobiography SDV6
Post #643559 Fri Aug 02 2024 7:55pm
Grimble
Just a word of warning, the sunroof drains holes have a small stubby pipe that the hose connects to. This pipe is prone to corrosion, causing the rubber drain hose to become detached and water to run down the roof lining. potentially causing mayhem with electrical systems.
There are a number of threads on this subject, I suggest a good read.
Its a relatively easy and inexpensive fix. RRS HSE Dynamic SDV6 2014
Post #643581 Mon Aug 05 2024 8:31am
markiep1
I wonder if the extended warranty would cover the electrical damage! You’d think they would have modified the pipe in its early stages once it became apparent there was a fundamental problem Shocked
Post #643584 Mon Aug 05 2024 9:37am
