![]() | Home > General > Dreaded Water In Rear Passenger Footwell |
Karlp606 Member Since: 25 Jun 2022 Location: East Yorks Posts: 254 ![]() |
So checked my sunroof and found the rubber seal is folding outwards, the when the sun roof is retracting to be open the rubber seal is folding outwards then not folding back inwards
Just actually double checked what I thought was a break in the seal is just where the seal ends - its the same on the other side - so the leak maybe from where the rubber seal was turned up?
karlos01 Member Since: 02 Jan 2022 Location: norfolk Posts: 309 ![]() ![]() ![]() |
what year of manufacture is yours |
2014 L494 matey |
don't the drain plugs run down the door pillars on that model |
I think the front ones do but Im not sure where the rear ones are to check if there blocked up? |
The drains run down the C pillar I belive so would think it the back quarter window panel and out through the rear wheel arches |
Thanks |
Just a quick thought do I need to remove the gloss black trim that runs the length of the car to access the drain holes?
you might have to I would of thought
Just a quick update on this looks like the slight leak I had into the head lining was due to the amount of rain that fell that day - very very heavy downpour, everything has been dry since in normal rain and driving through normal rain.
