Home > General > Dreaded Water In Rear Passenger Footwell |
Karlp606 Member Since: 25 Jun 2022 Location: East Yorks Posts: 241 |
So checked my sunroof and found the rubber seal is folding outwards, the when the sun roof is retracting to be open the rubber seal is folding outwards then not folding back inwards
Tue Nov 22 2022 12:25pm |
Just actually double checked what I thought was a break in the seal is just where the seal ends - its the same on the other side - so the leak maybe from where the rubber seal was turned up?
Tue Nov 22 2022 12:59pm |
karlos01 Member Since: 02 Jan 2022 Location: norfolk Posts: 309 |
what year of manufacture is yours |
Tue Nov 22 2022 1:02pm |
2014 L494 matey |
Tue Nov 22 2022 1:06pm |
don't the drain plugs run down the door pillars on that model |
Tue Nov 22 2022 1:22pm |
I think the front ones do but Im not sure where the rear ones are to check if there blocked up? |
Tue Nov 22 2022 1:25pm |
The drains run down the C pillar I belive so would think it the back quarter window panel and out through the rear wheel arches |
Tue Nov 22 2022 1:34pm |
Thanks
Tue Nov 22 2022 1:40pm |
Just a quick thought do I need to remove the gloss black trim that runs the length of the car to access the drain holes?
Tue Nov 22 2022 2:15pm |
you might have to I would of thought
Tue Nov 22 2022 6:29pm |
Just a quick update on this looks like the slight leak I had into the head lining was due to the amount of rain that fell that day - very very heavy downpour, everything has been dry since in normal rain and driving through normal rain.
Sat Dec 03 2022 2:40pm |
