![]() | Home > General > 2010 TDV8 Engine Oil Leak |
Raysunners Member Since: 20 Sep 2021 Location: Liverpool Posts: 14 ![]() ![]() ![]() |
Can be the camshaft seal at the back of the engine where the rear belt is, assuming its rrs |
Meiang Member Since: 29 Apr 2011 Location: Perth Posts: 394 ![]() ![]() ![]() |
Its a TDV8 not a TDV6. |
NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 443 ![]() ![]() ![]() |
Oil cooler?
From memory there is no plug at the bottom of the bell housing on my vehcile. The last time I did an oil change I wiped the bellhosing/tramission area because there was a slight weep oil and I did not notice a plug. Had I I would have removed it to see if oil was draining out. |
