Home > General > 2010 TDV8 Engine Oil Leak
Meiang
Australia 2010 Range Rover Sport TDV8 HSE Santorini Black
I have an engine oil leak on my 2010 TDV8 which apears to come from the bellhouse/transmission connection. The leak is quite bad lossing about 0.5 to 1 litre every few thousand km's. My 1st thought is the crank seal is passing oil. Are there any other leak areas I should be looking for.
Post #627766 Sat Oct 29 2022 1:01pm
Raysunners
United Kingdom 2011 Range Rover Sport SDV6 Autobiography Sumatra Black
Can be the camshaft seal at the back of the engine where the rear belt is, assuming its rrs
Post #627769 Sat Oct 29 2022 3:41pm
Meiang
Its a TDV8 not a TDV6.
Post #627779 Sat Oct 29 2022 10:50pm
NoExpert
Oil cooler?
If you can get to the plug in the bottom of the bell housing, remove it and try to look if there’s oil in there. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #627782 Sun Oct 30 2022 10:21am
Meiang
From memory there is no plug at the bottom of the bell housing on my vehcile. The last time I did an oil change I wiped the bellhosing/tramission area because there was a slight weep oil and I did not notice a plug. Had I I would have removed it to see if oil was draining out.
Post #627783 Sun Oct 30 2022 11:00am
