Home > General > Bluetooth Module |
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1829 |
Here are your photos
Sat Oct 22 2022 1:58pm |
V6gto Member Since: 22 Oct 2022 Location: Norfolk Posts: 7 |
wow, 78 reads and no advise, very sad about that |
Sun Oct 23 2022 2:52pm |
Stay calm!
Sun Oct 23 2022 3:42pm |
aaronjb Member Since: 26 Jun 2019 Location: Northampton Posts: 447 |
https://parts.jaguarlandroverclassic.com/p...and-rover/ suggests that even for your year (there were a lot of changes by year - 2009 and earlier, 2010 and 2011 and later are all different systems) the Telematics (the telephone BT module) is in the boot: https://parts.jaguarlandroverclassic.com/p...and-rover/
Sun Oct 23 2022 3:55pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4969 |
The only modules behind the rear boot panel on my 12/13 are the dab receiver, audio amp and RSE module. I do recall seeing this extract previously though, which may mean that bluetooth module is now a integrated part the IAM unit on that year vehicle, as the name suggests a picture of which you posted.
Sun Oct 23 2022 10:32pm |
Today I learnt that the later L320s do Bluetooth audio streaming.. I wonder if the telematics moved into the headunit at that point - that would make sense. 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S |
Mon Oct 24 2022 8:19am |
TheWojtek Member Since: 08 May 2015 Location: PoznaĆ, Poland Posts: 737 |
Bosch headunits (USB, not FireWire satnav update, modern graphics, not the JLR curved screen buttons) in MY2012 are able to stream audio, I believe. Regards etc.,
Mon Oct 24 2022 5:20pm |
Should have this in the Menu with Bosch IAM unit.
Mon Oct 24 2022 8:06pm |
thank you all for replies and sorry for not replying earlier as have been away for week, I will try suggested things |
Sun Oct 30 2022 12:29pm |
So i have plugged head unit in minus the fibre optic lead and switched ignition on and the fibre optic light in the back of unit flashes but the is nothing flashing from the fibre optic plug that plugs into the unit. also on front screen the audio is greyed out wether fibre optic lead is plugged into back or not, and i am not able to go into audio setting to bring up blue tooth. PLEASE does anyone know where the fibre optic cable that plugs into back of head unit comes from ?
Sun Oct 30 2022 12:50pm |
karlos01 Member Since: 02 Jan 2022 Location: norfolk Posts: 309 |
Sun Oct 30 2022 1:42pm |
Thanks karlos01, i have seen that video, but I'm not partially electrically minded, i have the car booked into a place in norwich next week. as i said in my original post some one told me it would probably be the bluetooth module in the boot compartment but its not there, |
Sun Oct 30 2022 7:28pm |
also karlos01 I see you are located in Norfolk, do you know of anyone or where that could sort it for me ? |
Sun Oct 30 2022 7:29pm |
That video is a RRS2 so probably find a lot of the components are in a different location to the RRS1.
Sun Oct 30 2022 7:49pm |
