Home > Technical > Suspension let down |
alfapat Member Since: 25 Sep 2021 Location: Elgin Posts: 210 |
Tue Oct 18 2022 8:01pm |
Lrstaylor Member Since: 10 Mar 2022 Location: Kent Posts: 344 |
Slow to raise is a fair bet the compressor is weak. You say seal kit ?? What exactly did you replace? |
Tue Oct 18 2022 8:46pm |
4x4 Airseals supply kits for solenoids front and middle and rear, rears have never been touched as never been a problem . However the compressor seals and the filter drier have been changed plus the the seals on the voss pipe connections . The front solenoid complete has been changed for lessor priced one , but meanwhile I have the RR one refurbished with a full seal kit change .The main tank is new also. So pretty extensive overhaul.
Wed Oct 19 2022 8:12am |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4393 |
New compressor time
Wed Oct 19 2022 9:46am |
Always open to help Mike, thanks suspension has been ok for a few months and more since all that work was done , does look like compressor. I'll check power at the w/e if I can get it up off the ground ! |
Wed Oct 19 2022 10:10am |
Using GAP, and live values , as I can't get to the plug at the moment. I went straight to live values on start up as the module takes a little more time to begin its checks and the compressor V showed 13 very briefly and the dash cut to the symbol with suspension fault , with voltage at 0v.
Wed Oct 19 2022 7:23pm |
Ign on
Wed Oct 19 2022 7:46pm |
ON THE CASE ! |
Thu Oct 20 2022 5:22pm |
On instruction , and what confirms my thinking advised by Micky disco , I screen shot the suspension live values when selected and then the ign switch on and start , I get this
Thu Oct 20 2022 5:44pm |
So trying to be sensible and not paying for genuine at £900
Thu Oct 20 2022 6:26pm |
aaronjb Member Since: 26 Jun 2019 Location: Northampton Posts: 447 |
Received wisdom is that the very cheap eBay versions last anywhere from days to weeks.. Advanced Factors have AMK for £477 and Hitachi for £500ish, though. 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S |
Fri Oct 21 2022 8:44am |
Awaiting 2nd hand compressor that says it new condition with 6mths warranty , not a bad price at £219. |
Sun Oct 23 2022 9:26pm |
Right? You only have to look at the first two entries in the cars in my signature... 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S |
Mon Oct 24 2022 1:36pm |
You need to be more specific , sorry. |
Mon Oct 24 2022 8:18pm |
