![]() | Home > Technical > Suspension let down |
alfapat Member Since: 25 Sep 2021 Location: Elgin Posts: 210 ![]() ![]() ![]() |
So RR back on its feet . Got an AMK , BUT NOT GENUINE WITH 12MTH WARRANTY AND PAID £332 all in. We will see haw it lasts. |
Ok to add, First two nights or 24hrs the suspension dropped 10mm, So levelling out and coming up to scratch immediately . I can put up with this and live in the thought that something is still leaking . Further Investigations?
erickwan Member Since: 27 Mar 2016 Location: P Jaya Posts: 138 ![]() ![]() |
Isn't the exhaust solenoid part of the pump?
Yes , the exhaust is part of the pump, correct. I changed over the solenoid with the original AMK one and it works normally on both sides, that is exhaust and pump pressure . Every corner drops in 24hrs but only by 15mm. However not ideal. I've had enough for the moment until I take the fuse 26,( I think that's the number) , I can then catch out the corner or valve that is letting the side down , so to speak! |
