Home > General > Slight. Strange L320 starting issue |
karlos01 Member Since: 02 Jan 2022 Location: norfolk Posts: 302 |
check the battery terminals are tight they might just be a little loose |
Sun Oct 09 2022 9:47pm |
Toonraider Member Since: 15 May 2022 Location: Newcastle upon Tyne Posts: 95 |
Proper tight. Its weird, like a split second cut off before it cranks again to fully start. |
Mon Oct 10 2022 12:15pm |
could be loose wire on the starter or bad earth on it |
Mon Oct 10 2022 1:14pm |
Will check that at weekend. Is it accessible? |
Tue Oct 11 2022 6:22pm |
you got petrol or diesel one |
Tue Oct 11 2022 8:39pm |
Diesel 2.7 |
Wed Oct 12 2022 6:57pm |
NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 463 |
How’s the battery check out?
Wed Oct 12 2022 8:06pm |
Aye, good shout that. How can I test that or is it just change it regardless and hope that's the issue. |
Thu Oct 13 2022 4:53pm |
That would be difficult to test. Could try testing resistance when cold and then when hot. However, if it’s only a second or so it stops you may not see much on the meter. Could try making a heat shield for it or getting a heat shield blanket for it. I’m definitely thinking heat soaked starter since my R1 would do the exact same thing. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Thu Oct 13 2022 6:32pm |
Good tip, cheers. Its less than a second if I'm honest. |
Fri Oct 14 2022 8:58pm |
