Home > General > Fuel Burning Heater
Page 12 of 12 <123 ... 101112
bajer
sorry not for this post
Post #520039 Mon Mar 06 2017 9:56am
RRS_Finland
Finland 2011 Range Rover Sport 3.0 TDV6 HSE Bourneville
Just to be sure...
I will need the following parts for the FBH remote control on my MY2011 RRS HSE, right?
LR008654 Antenna
LR036695 Receiver
LR027493 Remote
Thanks,
A-P
Post #556617 Wed May 16 2018 1:22pm
Gumby
England 2012 Range Rover Sport SDV6 HSE Lux Orkney Grey
Re: FBH Fuel Burning Heater Remote Operation
JUCOTT01 wrote:
Hi All
I just installed the remote option on my RRS
This will work for MY10 onwards ONLY
First of all remove the rubber trim on the boot and also on the drivers side rear door to enable the interior rear quarter panel to be removed
The receiver fits in the yellow circle marked below
Look out for the plug this will go into the receiver
You will also need to remove the shroud around the rear seat belt but its dead easy this will give you good access to behind the roof lining
The antenna just plugs in to the receiver and runs up and sticks to the roof,it has double sided sticky tape on it.
it should now look like this
Once you have put it all back together you will need to pair the remotes
Unplug fuse number "2" in the engine compartment (Brown fuse 5amp) far back right hand side for 5 seconds
Within 5 seconds of plugging the fuse back in press the OFF button for 1 second
If you already have "TIMED CLIMATE" you will probably need to get the "PARK HEAT REMOTE" activated
If you have nothing at all at the moment then you can activate them both at the same time
JOB DONE Thumbs Up Thumbs Up
Here is the parts i used
The remote fob i got off E-Bay for �25 (Land Rover Branded)
Bring On The Winter Chill
Mr. Green Mr. Green Mr. Green
Bit of a bump, but just wanted to say that’s possibly one of the most helpful posts I’ve ever seen!
The only thing I could add is that on an MY2012 model, the bracket looks slightly different:
Just need to find someone to code it now!
Post #627072 Sun Oct 02 2022 6:58pm
GunnerBill
United Kingdom 2008 Range Rover Sport TDV6 HSE Stornoway Grey
https://trialsofarrsowner.wordpress.com/fu...bh-issues/
I found this very useful to me as an introduction and a bit of a resource if like me you think yours isn't working.
Post #627167 Tue Oct 04 2022 7:33pm
