Home > Orders (L461) > SE vs Dynamic SE |
Tim oop north Member Since: 10 Sep 2022 Location: Preston-ish Posts: 32 |
I don’t like the dynamic’s copper effect finish bits, didn’t want the darker wheels, and the other changes had no benefit to me at all, but it’s all a matter of taste (I’ve gone for the “country” look), so you pays your money and takes your choice! |
Sun Sep 25 2022 6:41pm |
mazj Member Since: 12 Sep 2022 Location: Bucks Posts: 15 |
Very true,
Tue Sep 27 2022 9:57am |
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1843 |
Look the same to me! 2023 P440e SE Dynamic on order -cancelled
Tue Sep 27 2022 11:09am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9003 |
Is Dynamic now just an aesthetic difference like it is on the Disco 5? It used to be mechanical differences and was well worth having. 2012 SDV6 - it's missing a couple of cylinders
Thu Sep 29 2022 11:17am |
Yes - it’s entirely cosmetic and external (ie, no interior differences) |
Thu Sep 29 2022 11:20am |
AlM Member Since: 08 Feb 2021 Location: Melbourne Posts: 52 |
On the 494 in Australia, the Dynamic included the so-called “dynamic driving mode”, which I understood allowed you to configure throttle, steering, and suspension response. Is that no longer the case with the new model or is it now standard? MY21.5 HSE 221KW D16
Thu Sep 29 2022 9:05pm |
timhum Member Since: 06 Mar 2017 Location: Suffolk Posts: 389 |
Now standard. Tim
Thu Sep 29 2022 9:22pm |
MikeJG Member Since: 30 Aug 2022 Location: Shropshire Posts: 65 |
Although I don't wish to contradict an honorable member, I think there is a significant interior difference between SE and R Dynamic if you choose an interior other than black and that is that the SE is monotone and the R Dynamic is duotone with black. Please correct me if I'm wrong. BTW, finally saw a Giola Green FE in Listers in Hereford showroom. That is a tick for me. |
Fri Sep 30 2022 1:17pm |
Milky400 Member Since: 11 Aug 2022 Location: cambridge Posts: 92 |
Also think the roof linings are different I.e black standard on dynamic? |
Fri Sep 30 2022 4:48pm |
Is it? I just priced one up (to get the brochure for what I’ve orders) and config dynamic is still and extra, and a waste of money. Had it on the velar, used it once and that was it. 😂 |
Fri Sep 30 2022 4:49pm |
The off-road configurable dynamics are an extra but the regular config dynamics are listed under standard features. I've found this very useful being able to choose what to switch on or off, I like to use the dynamic setting on steering and suspension but keeps others as regular. Tim
Fri Sep 30 2022 5:09pm |
That’s true, the velar has that and everything is turned up and never changed 😂 |
Fri Sep 30 2022 5:32pm |
100% correct. |
Fri Sep 30 2022 8:27pm |
L461 doesn't the active rear diff even as an option, does it? Only on the 510bhp versions along with the rear steer system.
Sat Oct 01 2022 4:28pm |
