![]() | Home > Orders (L461) > SE vs Dynamic SE |
Tim oop north Member Since: 10 Sep 2022 Location: Preston-ish Posts: 32 ![]() |
I don’t like the dynamic’s copper effect finish bits, didn’t want the darker wheels, and the other changes had no benefit to me at all, but it’s all a matter of taste (I’ve gone for the “country” look), so you pays your money and takes your choice! |
mazj Member Since: 12 Sep 2022 Location: Bucks Posts: 15 ![]() ![]() |
Very true,
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1865 ![]() ![]() |
Look the same to me! |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9039 ![]() ![]() ![]() |
Is Dynamic now just an aesthetic difference like it is on the Disco 5? It used to be mechanical differences and was well worth having. 2012 SDV6 - it's missing a couple of cylinders
Yes - it’s entirely cosmetic and external (ie, no interior differences) |
AlM Member Since: 08 Feb 2021 Location: Melbourne Posts: 52 ![]() ![]() |
On the 494 in Australia, the Dynamic included the so-called “dynamic driving mode”, which I understood allowed you to configure throttle, steering, and suspension response. Is that no longer the case with the new model or is it now standard? MY21.5 HSE 221KW D16
timhum Member Since: 06 Mar 2017 Location: Suffolk Posts: 389 ![]() ![]() |
Now standard. Tim
MikeJG Member Since: 30 Aug 2022 Location: Shropshire Posts: 65 ![]() ![]() |
Although I don't wish to contradict an honorable member, I think there is a significant interior difference between SE and R Dynamic if you choose an interior other than black and that is that the SE is monotone and the R Dynamic is duotone with black. Please correct me if I'm wrong. BTW, finally saw a Giola Green FE in Listers in Hereford showroom. That is a tick for me. |
Milky400 Member Since: 11 Aug 2022 Location: cambridge Posts: 92 ![]() ![]() |
Also think the roof linings are different I.e black standard on dynamic? |
Is it? I just priced one up (to get the brochure for what I’ve orders) and config dynamic is still and extra, and a waste of money. Had it on the velar, used it once and that was it. 😂 |
The off-road configurable dynamics are an extra but the regular config dynamics are listed under standard features. I've found this very useful being able to choose what to switch on or off, I like to use the dynamic setting on steering and suspension but keeps others as regular. Tim
That’s true, the velar has that and everything is turned up and never changed 😂 |
100% correct. |
L461 doesn't the active rear diff even as an option, does it? Only on the 510bhp versions along with the rear steer system.
