![]() | Home > General (L494) > Sensor for DPF - engine removal |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9014 ![]() ![]() ![]() |
Presumably the garage it's current in isn't an independent LR specialist - any decent LR specialist ought to be able to remove the engine and do it at a significantly lower cost than a Land Rover main dealer. They'll likely also be able to do it all without causing damage to the car. I'd be very wary about letting a LR main dealer do something as complicated as removing the engine. 2012 SDV6 - it's missing a couple of cylinders
John1311 Member Since: 05 Jul 2012 Location: Devon Posts: 40 ![]() ![]() |
yes its Mike Harding in Bovey Tracey one of the only local indys' to us - so was surprised they wouldn't do it - they have removed the body off a previous sport to do the turbos - so now unsure what to do 2016 Range Rover Sport SDV6 autobiography (MY17)
Red Arrow Member Since: 06 Jun 2017 Location: Scotland Posts: 590 ![]() ![]() |
Drop Disco Mikey a PM |
where in the country is he based? 2016 Range Rover Sport SDV6 autobiography (MY17)
Up here in Dundee , but he has immense knowledge of all things Land Rover |
Call Steve Norman in Shepton Mallet I would. T&S Norman. He's a guru and not too far from you Visitor from fullfatrr.com * GONE. 2012 RR Sport HSE SDV6 Orkney Grey. Now being piloted by RRSTDV8 * GONE: 2011 4.4 TDV8 Full Fat. Amazing piece of kit. * Current. 1974 Lightweight 2.25L petrol. Old skool * GONE. Freelander GS TD4 Manual MY2013. Orkney Grey with privacy, cold and clearview packs, armrests (a must!) and a spoiler. * GONE. Range Rover Classic '93 200Tdi Factory fit * 1949 80" in family since 1975 |
will do many thanks 2016 Range Rover Sport SDV6 autobiography (MY17)
I use exclusively T&S and Steve and George absolutely brilliant. 2006 2.7 TDV6 HSE in Cairns Blue. |
