![]() | Home > General > Sidesteps again |
Dicer Member Since: 14 Aug 2022 Location: Somerset Posts: 10 ![]() ![]() |
Don’t worry I think I’ve sussed it, in too much of a rush as usual. |
karlos01 Member Since: 02 Jan 2022 Location: norfolk Posts: 309 ![]() ![]() ![]() |
what rrs do the brackets fit please
2013-2022 stated on the website |
Sudds Member Since: 02 Mar 2015 Location: North Yorkshire Posts: 36 ![]() ![]() |
Just fitted the same steps to mine and I think they are so much better than some offerings out there as the rubber tread wraps around the edge.
I'll have a look as I've got a 2006 |
Hi Sudds
The rear brackets on mine lined up ok, the 2 front holes nearest the sill required the bolts to fit through the bracket and the bolt at the back stayed in the bracket and slid into o hole in the chassis and then clamped up as i tightened the bolt, it does allow the bracket to slide to fit the front bolts.
Cheers Sudds
Red Arrow Member Since: 06 Jun 2017 Location: Scotland Posts: 590 ![]() ![]() |
I have a good set of the alloy brackets for the L494 never been fitted
Thanks for the offer I will bear it in mind, I’ve emailed the company that supplied them hopefully they will sort me out. |
I found their customer support was really good when i had a query. Heather passed on my query to Reece and he phoned me back within 10 minutes to answer my question. |
I’ve spoken to Reece and Heather this morning and they are putting a replacement in the post today, I understand things like this happen but the sign of a good company is how they sort a problem out and I must say they are excellent. |
