Home > General > Oil Filler Cap
Craig_John
Oil Filler Cap
All,
Oil change was going great and the plastic part that secures the filter cracked when I was taking it off. So I’m left with the car with no oil in and I can move it.
The LR part number is LR013147 and I can’t get anything local. Does anyone have any idea if other model parts fit?
Part image below
Thank you
Post #625957 Sat Aug 06 2022 10:00am
jaguar 2.7 (S type, XJ6 x350, XF 2.7)
and I think
citroen c6 2.7
peouget 2.7
Post #625962 Sat Aug 06 2022 11:54am
You don't need to torque them up. Just tighten them till they stop turning
https://www.ebay.co.uk/itm/255166046265?ep...SwEuxhXZdT
Post #625963 Sat Aug 06 2022 11:56am
Oh and the oil filters are different between 2.7 and 3.0
so I assumed the cap was too
Post #625964 Sat Aug 06 2022 11:58am
oh and it really helps if you fill in your profile, then I'm not assuming you have a 2.7 and giving you the wrong parts and info Rolling Eyes
They did a jaguar XF 3.0 i think, maybe
Post #625965 Sat Aug 06 2022 11:59am
Based on a previous post in the L494 section I think the OP has a 2016 L494 3.0L, and why would you not bother to torque the cap up when it does actually have a figure of 25Nm moulded in to the cap for this purpose, presumably amongst other things to stop it being over tightened and possibly cracking being some sort of plastic composite material.
Post #625981 Sat Aug 06 2022 11:44pm
NoExpert
Citroen part number 1103 T4. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #625982 Sun Aug 07 2022 4:45am
Craig_John
All,
Thank you very much for all your help, I really appreciate it.
Is there anyway to flush the oil filter section, pour some oil down it with the sump plug out? I’m a bit worried some filter material, plastic shards may have got in there?
I’ll try and update my profile, but I can see where to do that.
Regards
Post #625995 Mon Aug 08 2022 1:48pm
