Home > Technical > L494 4.4 P006A-84(27) restricted performance fault
PC76
Hi all I have just come back from a weekend away with the caravan and whilst towing uphill I got the restricted performance warning. I plugged in my IID and got the following fault code.
P006A-84 (27) Manifold absolute pressure - mass or volume air flow correlation - Bus signal/message failure - signal is below allowable range
Now my old 2010 sport had a similar issue and ended up being a split manifold and I hoped I had let all those worries behind with the 4.4 😰.
A brief search mainly brought back split hoses, leaking manifolds and blocked DPF’s but didn’t see anything that related specifically to the 4.4 engine. So I’m after some help to identify the problem.
Thx 2015 4.4 Autobiography
2010 3.0 HSE 162K - Gone
Post #625810 Mon Aug 01 2022 6:02pm
Disco_Mikey
They suffer from split turbo hoses between the plenum and manifolds mostly
They do also suffer from split plenum and manifolds, but quite rare (so far)
Post #625814 Mon Aug 01 2022 8:28pm
PC76
Thx DM.
I assume then a physical check is needed or would a Jerry rigged low pressure smoke test do the trick? 2015 4.4 Autobiography
Post #625817 Mon Aug 01 2022 10:03pm
PC76
Hi DM, would you be referring to this part?
https://www.lrparts.net/lr056285.html 2015 4.4 Autobiography
Post #625907 Thu Aug 04 2022 4:05pm
