![]() | Home > Faults & Fixes > Suspension fault C1A20-64 - how to fix |
Lrstaylor Member Since: 10 Mar 2022 Location: Kent Posts: 348 ![]() ![]() ![]() |
Don't forget a bad air tank can cause this as was the case on the wife's D3 recently. |
pomistea Member Since: 03 Jun 2021 Location: Dublin Posts: 43 ![]() ![]() ![]() |
Hi @Lrstaylor
https://disco3.co.uk/forum/new-suspension-compressor-197388.html |
Thank you.
Soapy water if good plus you can here a leak if your lucky |
Thank you, I'll try to get at it.
ZED_31 Member Since: 01 Dec 2022 Location: Chassal-Molinges Posts: 5 ![]() ![]() |
Hello Ignas,
Has anybody been able to get in touch with Ingas ?
If your desperate have a look here,, they keep various types of repair kits. I rebuilt my compressor with one of their kits.
Hi
ch1819 Member Since: 14 Jun 2024 Location: Florida Posts: 1 ![]() ![]() |
Welp, this is a super-old thread, but hoping someone still has a line of these kits...genius...
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5066 ![]() ![]() ![]() |
Is this the kit you are referring to?
Got mine from an outfit on eBay,,, 4x4 air seals,, they do various kits depending on what you want to do from full rebuild to dryer or valve block service.
