Home > General (L494) > New Owner :) - Couple of quick ones - Electrical based |
Coedlan Member Since: 30 Sep 2016 Location: N. Wales Posts: 71 |
Oil question is simple, though baffling as to why LR designed such a daft system
Sat Jun 25 2022 6:31pm |
Karlp606 Member Since: 25 Jun 2022 Location: East Yorks Posts: 241 |
Ah I tried the oil indicator at the dealers but had only been running for 5 mins and I tried when I got back but car had been running for a good 4 hours after driving - just see the bonnet trick will check that out tommorrow. |
Sat Jun 25 2022 6:35pm |
Going to try the bonnet trick this morning to get the oil level.
Mon Jun 27 2022 6:20am |
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1829 |
You will not need the bonnet trick, if the car has not been started.
Mon Jun 27 2022 7:45am |
Still struggling with the oil level indicator
Mon Jun 27 2022 4:10pm |
There are/were several stages of Meridian, you may have the basic? 2023 P440e SE Dynamic on order -cancelled
Mon Jun 27 2022 4:25pm |
Ah :/ that’s maybe why I can’t see a surround sound option, but have the 3 other sound options but obviously can’t select them :/ - not sure if it’s an amp issue or electrical issue as the sub is non existent when I turn the level to max. |
Mon Jun 27 2022 7:21pm |
Barryp Member Since: 05 Nov 2011 Location: Sydney Posts: 261 |
There was an advisory to dealers on the oil level indicator. Mine was fixed under the original warranty before the 3 years was up. Oil flows up the wiring in the sump basically stopping the signal from getting to the computer. Its an expensive item to get fixed. Basically it is a stupidly designed system to replace a dipstick!
Tue Jun 28 2022 1:19am |
Thanks Barry - looks like it will be the sensor - so I’m covered under my extended warranty so will get that sorted.
Wed Jun 29 2022 3:00pm |
Red Arrow Member Since: 06 Jun 2017 Location: Scotland Posts: 585 |
Approx 1 litre from min to max and is 125ml per section on the indicator
Wed Jun 29 2022 3:49pm |
Did you try the oil level check with the engine warm, level ground etc? I guess you did but still not available?
Wed Jun 29 2022 3:52pm |
Ah cool thanks for the replies guys - I'll prob leave it for now until its booked in then.
Wed Jun 29 2022 4:07pm |
Yeh tried all the usual tricks to get it to show including the bonnet open and pressing cancel twice etc |
Wed Jun 29 2022 4:09pm |
Interesting thought, though if the sensor is goosed then an obd wouldn’t get the data either? I did wonder if a length of bicycle brake wire or similar could be fed down the oil extraction pipe to “dip” the oil level. Haven’t (yet) tried it, but the bends in the pipe look tight so may not be possible? 2016 L494 HSE |
Wed Jun 29 2022 7:14pm |
