Home > Technical > Sport 5.0s/c |
Cosmo15555 Member Since: 24 Jun 2014 Location: Stevenage Posts: 163 |
I’m still trying to find the problem |
Wed May 25 2022 10:41pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4970 |
Could try swapping MAF sensors over bank 1 to bank 2 and visa-versa, if code changes to P0174-00 would indicate a faulty MAF sensor, as code refers to MAF and Cat sensors, also possible air leak on air intake system. The two sensors are identical and interchangeable just look different as they are mounted at different angles. Only a suggestion.
Wed May 25 2022 11:33pm |
I’ve not been in a hurry to remedy this as not caused any problem with performance
Sun Aug 07 2022 4:18pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4941 |
well -30 seams a silly value.
Sun Aug 07 2022 4:46pm |
As I look at the car from the front which side is bank 1 |
Sun Aug 07 2022 11:02pm |
L/H side. R/H when sat in drivers seat.
Sun Aug 07 2022 11:21pm |
Thanks for the info |
Mon Aug 08 2022 6:44am |
I’ve cleaned the mass air flow sensors and still getting same reading so I swapped the sensors over and still the same reading as before
Mon Aug 08 2022 5:22pm |
Checking other different live values I’ve found this
Mon Aug 08 2022 5:58pm |
After doing a lot of research on web some people saying pcv diaphragm can cause the same fault codes
Mon Aug 08 2022 7:07pm |
If you have a hisssing then fix it |
Mon Aug 08 2022 7:17pm |
Lrstaylor Member Since: 10 Mar 2022 Location: Kent Posts: 344 |
Mon Aug 08 2022 9:16pm |
