![]() | Home > Technical > Sport 5.0s/c |
Cosmo15555 Member Since: 24 Jun 2014 Location: Stevenage Posts: 163 ![]() ![]() ![]() |
I’m still trying to find the problem |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5066 ![]() ![]() ![]() |
Could try swapping MAF sensors over bank 1 to bank 2 and visa-versa, if code changes to P0174-00 would indicate a faulty MAF sensor, as code refers to MAF and Cat sensors, also possible air leak on air intake system. The two sensors are identical and interchangeable just look different as they are mounted at different angles. Only a suggestion.
I’ve not been in a hurry to remedy this as not caused any problem with performance
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5037 ![]() ![]() ![]() |
well -30 seams a silly value.
As I look at the car from the front which side is bank 1 |
L/H side. R/H when sat in drivers seat.
Thanks for the info |
I’ve cleaned the mass air flow sensors and still getting same reading so I swapped the sensors over and still the same reading as before
Checking other different live values I’ve found this
After doing a lot of research on web some people saying pcv diaphragm can cause the same fault codes
If you have a hisssing then fix it |
Lrstaylor Member Since: 10 Mar 2022 Location: Kent Posts: 348 ![]() ![]() ![]() |
