Home > Technical > Seeking advise |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4967 |
Listen for chain rattle from front of engine.
Sun May 15 2022 10:34pm |
Amolkarnik Member Since: 15 May 2022 Location: Milton Keynes Posts: 3 |
Thanks. Is this likely to be an issue on an engine with just 35000 km (21k miles on it?) |
Mon May 16 2022 2:39am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4986 |
Very unlikely, according to L/R the initial timing chain/tensioner/guide issues that they had with the 5.0L engine they rectified about 10 years ago by fitting modified tensioners/guides etc. Although anything mechanical or electrical can fail, but I think the odds are in your favour with the engine.
Mon May 16 2022 3:20am |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1067 |
When they pulled the engine they would have had top pull the torque converter off with all the gearbox oil it holds so that is why you would have had 3l of transmission oil when the engine was done. 07MY RRS TDV6
Mon May 16 2022 5:23am |
Deep92 Member Since: 23 May 2022 Location: London Posts: 7 |
useful thanks |
Wed May 25 2022 11:16am |
