Home > Maintenance & Modifications > 2.7 2005 ns head removal. |
kas982 Member Since: 03 Oct 2021 Location: west mids Posts: 53 |
if you have a lift, its easier to lift the bod away fronm the chassis, remove the air con gas, if you dont have a machine get a mobile guy out. |
Sun May 01 2022 2:44pm |
looneyfitter Member Since: 13 May 2012 Location: liverpoool Posts: 212 |
Is there a how to on how to lift it mate? |
Sun May 01 2022 4:58pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4966 |
Couple over here and video on YouTube by pistonsbroke
Sun May 01 2022 6:30pm |
How long would you say it takes to remove the body mate? If its not that long, then may be worth it as I would strip the OS head too and replace the chain and valve seals.
Sun May 01 2022 7:30pm |
Dunno
Mon May 02 2022 9:00am |
Your not wrong there. Im already thinking of whipping the os head off, doing the gasket, all seals etc. Injectors, stems.
Mon May 02 2022 10:55am |
Have a look over on disco3 for inspiration |
Mon May 02 2022 4:31pm |
Busy day today. Managed to lift the body and pull both the heads off. Pots and pistons look spot on, still see the honing marks.
Wed May 04 2022 9:05pm |
Wed May 04 2022 9:06pm |
well if you remove the cam, turn the head upside down.
Thu May 05 2022 11:06am |
