![]() | Home > Wheels & Tyres > Hunter alignment. Anything I need to know beforehand? |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5063 ![]() ![]() ![]() |
Not sure just how much difference it will makes but this is from w/shop manual.
Cheers Col. Well it must be there for a reason. Thanks for confirming what I thought was internet tosh. 2006 2.7 TDV6 HSE in Cairns Blue. |
BJH1959 Member Since: 25 Mar 2017 Location: Paredes de Coura, Portugal Posts: 410 ![]() ![]() ![]() |
I've had 3 Hunter alignments and never knew this and the technicians have never mentioned it! I can see the rationale.
I would check that all of your suspension arms, bushes and associated components are all in good order. Otherwise you will be getting the alignment done to then disturb it by having to change something, you will then have to get it aligned again! |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9048 ![]() ![]() ![]() |
The vehicle should also be be put in to "tight tolerance" mode for the alignment. This just means the suspension works harder to get as close to level as possible. Technically, a Hunter place should have a dongle to set this but most don't as it's an expense for them if they don't do many LRs. Most will just leave the driver's door slightly open to stop the suspension moving around.
Thanks everyone. I’ve got an IID tool so am happy to set prior when I arrive on site. Next how do I do that within the settings? 2006 2.7 TDV6 HSE in Cairns Blue. |
Tool Menu > Service/Test > RLM-Suspension > Set Tight Tolerance - Yes. Don't forget to take it out of Tight Tolerance when done. Easy as. |
Lovely cheers. |
Surely if your paying someone to carry out 4 wheel alignment you shouldn't have to do anything,,, they should know exactly what is required and have all the tools to carry out the job. I had mine done a few years ago at my go to place (( team valley landrover) issued prior to going about full fuel tank etc, they said it makes no difference. They use a Beisbarth ( spelling may he wrong) machine. 2010 RRS, TDV8
Maybe if they say "it makes no difference" then they don't know what they're doing. |
Simple solution have it done with empty fuel tank and not in tight tolerance mode, see what the readings are, then fill the tank, put it in tight tolerance have it checked again and compare the readings, if it makes no difference they should both be within the specified parameters. I know L/R do like to complicate things somewhat, but you would like to think they say full tank etc. for a reason.
Indeed so, Col.
An update to this. I rung last week and asked for the tyres I wanted (Continental Allseason Contact), they said no problem and a discounted price of £213ea from £224 was agreed. I received a text message the following day to say my tyres were in. So this morning I set off and went the 30 miles or so and they got going. They found the 2 NS wheels were buckled so I approved to have them repaired. All done I paid my dues which was cheaper than the amount I’d budgeted. I drove home and the drive was so smooth and back to how I remember it. This has also fixed my problem of the reluctance to change into sixth. When I got home I had a look at the tyres and read the receipt and they have fitted 275/40 R20 Continental Sport Contact 4x4s’. Now this is a summer tyre when I was looking to go to an all season. I’ve re-googled the original tyre and I can’t find them in my size, so obviously my mistake. So I feel it’s my fault for not researching further. Also with regards the free alignment within 3 months - they don’t do that anymore but would for me as if spent so much money.
syl Member Since: 10 Mar 2016 Location: Somerset Posts: 412 ![]() ![]() |
I’ve had my car aligned (not my RRS) several times over the years, including on a Hunter machine.
