Home > Technical > 4.2 Supercharged PCV System |
dhallworth Member Since: 13 Aug 2015 Location: Glasgow Posts: 40 |
I've been a member on FullFatRR.com for 11 years and have been wandering on and off the Sport forum for a while too as I've been trying to convince my wife to have a Sport.
Mon Apr 25 2022 2:36pm |
mgrover Member Since: 17 Oct 2019 Location: Leeds Posts: 393 |
Yeahh there was a jaguar post that had a similar problem. They basically just replaced the entire plastic pipe with a rubber one.
Mon Apr 25 2022 2:42pm |
I think the argument that was made was that its just badly designed pipe. I mean if you want to bypass if you can just install a catch can? |
Mon Apr 25 2022 2:58pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4944 |
I wouldn't rule out air leaks on these cars. Bloody annoying.
Mon Apr 25 2022 4:47pm |
I’m fairly certain there’s an air leak somewhere but if I know where to start looking.
Mon Apr 25 2022 6:52pm |
-3 is ok
Mon Apr 25 2022 8:16pm |
Is it likely to be an air leak that’s causing the fuel trims to be off kilter?
Mon Apr 25 2022 8:22pm |
I believe so.
Mon Apr 25 2022 8:56pm |
Just a thought, if it’s been on LPG for a while, I wonder if I should reset the adaptions and see what the trims settle down to them.
Mon Apr 25 2022 9:01pm |
yah id clear your adaptations and run petrol for a good tank.
Mon Apr 25 2022 9:51pm |
My biggest issue is whilst doing all my suspension work, the MOT has expired so the first trip I need to do is for the MOT where it'll be emissions tested. If something is wrong it'll end up failing the test on emissions I'd imagine. Especially as at idle that's when the misfire is noticeable. It's almost unnoticeable when hot so it might scrape through but I'd rather fix it then take a chance.
Tue Apr 26 2022 11:04am |
I'd take it to MOT with the LPG on. Since they don't really test the CATs.
Tue Apr 26 2022 3:02pm |
I think it stands a chance of passing an MOT.
Tue Apr 26 2022 4:10pm |
Done some more checking tonight.
Tue Apr 26 2022 5:53pm |
