![]() | Home > Technical > Tdv8 crank sensor location |
Lippyrrs Member Since: 04 Jun 2021 Location: Blackpool Posts: 1 ![]() ![]() ![]() |
Hi I have a 2009 facelift tdv8 and it’s throwing crank sensor codes, anyone have a guide on replacing or pictures of the location cheers |
I do hope you do not have to remove transmission/flexiplate to access it, which is what the workshop manual appears to imply.
HF-Martini Member Since: 09 Jul 2021 Location: Cambridgeshire Posts: 8 ![]() ![]() |
Hi there, just wondering if you managed to find the easier way of replacing your CKS?
Hi there,
Stewartb Member Since: 07 Jan 2022 Location: Scotland Posts: 5 ![]() ![]() ![]() |
Hi HF-Martini
sorry forgot but I have also checked that there is 12v leaving the fuel pump relay.
How do Stuart,
34jzgte Member Since: 18 Apr 2022 Location: Perth Posts: 2 ![]() ![]() ![]() |
I had this issue, it can be done without taking the bellhousing off the block, but it's not as easy as undoing the torx bolt and taking the sensor out and replacing, I did this and it wouldn't start, instead of taking everything apart for better access I sent a bore scope camera down there.
I have driven my tdv8 range rover sport for a week and can confirm my problem is gone now, original symptoms were car cranks but won't run, this was usually after a drive and I would stop for fuel or shops and it is very hard to start after that, if I leave the car sitting for over 4-5 hours it starts no issues.
