Home > General > My new to me 2006 supercharged fixes and faults. |
Lrstaylor Member Since: 10 Mar 2022 Location: Kent Posts: 341 |
Been having a good look around the engine bay today and think I've tracked down a slight clunk on idle, supercharger front pulley bearing seems to be shot. So will add a rebuild kit to my ever increasing parts list luckily I have access to a press. |
Sun Apr 03 2022 11:01pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8971 |
Sounds like a good project car, especially if you have access to garage facilities to do some / all of your own work.
Mon Apr 04 2022 8:32am |
Luckily I can do pretty much most stuff, I restored my P38 v8 when I got it from top end rebuild to air suspension rebuild, I run an m62 Fullfat which got its guides replaced last year and the wife's D3 keeps me busy but not to much more preventative stuff than faults. The rrs is pretty similar.
Mon Apr 04 2022 12:38pm |
Little update, found the O ring on the pcv valve shot so that's all done with a nice new O ring.
Sat Apr 09 2022 11:05am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4940 |
Gearbox cooler probably |
Sat Apr 09 2022 11:28am |
Yep, gearbox oil cooler. I followed the pipe back to the gearbox so another thing added to my list, I was going to do a gearbox flush anyways looks like soon than later. I will check the levels 1st.
Sat Apr 09 2022 11:37am |
Gearbox oil change is generally never that simple.
Sat Apr 09 2022 1:08pm |
Nice 1 Andy il get back under there tomorrow and have a look see. |
Sat Apr 09 2022 2:33pm |
It's the little things, engine cover mounting grommets x3 missing quick look in the garage, job done.
Sat Apr 09 2022 3:33pm |
With the side level plug.
Sat Apr 09 2022 3:45pm |
andy |
Sat Apr 09 2022 5:51pm |
I thibk i have a new pully and oil for that if you want to make me an offer but would need to check the garage to seeif its still there Lol |
Sun Apr 10 2022 9:40am |
Today was brake day, I usually pull the wheels off in the 1st week but due to other things it had to wait until today.
Fri Apr 15 2022 6:45pm |
Front brakes done new pads fitted the front discs are serviceable unlike the rears so time to turn my attention to the interior. I recently re glued the peeling cloth material on one A pillars. Drivers side I experimented with pva passenger side git good old spray contact glue, neither was much good.
Sat Apr 23 2022 12:42pm |
