Home > General > Engine system fault
Sean1884
United Kingdom 2008 Range Rover Sport TDV6 HSE Java Black
Engine system fault
Hi
I have a 2008 RR Sport 2.7 tdi HSE. Has done 86k miles. Had the car 1 month and dealer refuses to accept their issue. Had not been used for 6 months prior, evidenced by steering all stiff and joints needing to be lubricated. Has been running fine till I started getting fault light and going into limp mode. Normally after pushing car, but not excessive. Once I stop, turn off and on drives fine. Can happen a couple of times on a 10 mile journey. If I don't push the car generally no issue.
Struggled to find anything on here (probably my search skills). Any suggestions appreciated.
TIA
Sean
Post #623302 Sat Apr 02 2022 7:34am
Shaun W
Any smoke from the Exhaust?
On my TdV8 I have had:
Black smoke - Split Intercooler hose, easy fix to do.
White Smoke - For me EGR valve, but could also be Turbo - not an easy fix. 2010 HSE TdV8 in Stornoway Grey.
Powerful Roof Rails and Spare Wheel protector
Post #623385 Tue Apr 05 2022 8:46am
gogsy1956
Easiest and cheapest starting point would be to blank off the egr valves seeing as you have the 2.7,, only thing on yours is I think you may need a software update to keep the engine management light off,,,, then see how it goes. 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #623393 Tue Apr 05 2022 5:10pm
Sean1884
Thanks for the responses. Not aware of any smoke.
As for egr valve etc no idea how to do that.
I have it going into the garage Thursday so hopefully a simple fix
Post #623398 Tue Apr 05 2022 9:32pm
harry_57
United Kingdom 2007 Range Rover Sport TDV6 SE Ipanema Sand
Sean ... did you ever get it solved ?
Post #640153 Mon Mar 04 2024 9:26pm
