Home > Wheels & Tyres > Red diesel ?
Julio
England 2007 Range Rover Sport TDV8 HSE Zermatt Silver
Red diesel ?
Hi chums.
My RRS TDV8 2007 now showing 207,000 miles, and still purring along, everything working.
Forgive me for being dim, but can I run the old girl on red diesel ?
For use on private land obvo ...
Post #623200 Mon Mar 28 2022 11:03pm
I think you may have posted in the wrong section, but shouldn't be a problem, red used to be less refined then white but I think that's changed now with modern engine, now just the same except with a red dye, funnily enough in Ireland it's a green dye or used to be. Just don't get caught on the public roads running it or it could work out expensive. Unless you are using vast amounts personally I think I would stick with white.
Post #623201 Mon Mar 28 2022 11:25pm
Julio
Thanks Col, yes defiantly the wrong section. Bit dim me …
Post #623202 Tue Mar 29 2022 6:56am
According to this site https://craggsenergy.co.uk/red-diesel-facts/ red diesel has a lower cetane rating and so would need a cetane booster added to the fuel to run in your TDV8.
Be nice to the engine, buy it proper diesel. Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #623204 Tue Mar 29 2022 8:58am
Bertbuckie
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Bonatti Grey
It will run but tbh its hardly worth it these days
Post #623208 Tue Mar 29 2022 11:38am
DaftRascal
United Kingdom 2009 Range Rover Sport TDV8 HSE Santorini Black
Yes! you can and will have no unwanted issues. People have issues running red when they use dirty drums, get it from a less than clean source etc. Water in drums or just dirty whether it's been gear oil etc in the 5 gall drums.
Post #628085 Wed Nov 09 2022 9:23pm
Crs
England 2013 Range Rover Sport Supercharged Autobiography Firenze Red
I am afraid getting red Diesel is not as easy as it used to be, our Government have all but banned it , I can use it in my tractor on the fields but not on the road, most places won’t sell it to you.
Post #628086 Wed Nov 09 2022 9:35pm
DaftRascal
lots of filling stations round here sell
it out the pump. I've no idea costing of it but I am led to believe you need show id and give cause for its use. Heater etc being one that apparently works. Wouldn't be me in mine, to good a car to have the vosa and customs take off me.
Post #628089 Wed Nov 09 2022 10:50pm
Pufftmw
Though I've not had need to buy any this past year (I have a 40gallon drum's worth), all that's required is filling out your name/address/reg of vehicle buying it at the petrol station.
You can also buy delivered but minimum 500l, which I can't justify.
@Crs I thought it was still OK for tractors on the road if actually working, such as driving between fields etc but not for contracting or going to the market?
Post #628208 Sun Nov 13 2022 7:23am
