Home > General > Steering issue |
BJH1959 Member Since: 25 Mar 2017 Location: Paredes de Coura, Portugal Posts: 410 |
Possibly wheel balancing and/or tracking out. But I'm no expert. Barrie.
Wed Mar 23 2022 9:48am |
Baker3570 Member Since: 28 May 2021 Location: cumbria Posts: 53 |
ive got it booked in the garage for tuesday, soon as i said about it having a steering issue he said what the faults were im having before i had chance, apparently it could be the UJ on the shaft? which is a common fault for seizing up |
Thu Mar 24 2022 7:28pm |
Quite possibly UJs. This was the case when my steering got heavy. Some lubrication solved that, but I didn't have the steering wheel wobble at speed. Barrie.
Fri Mar 25 2022 6:39am |
so its been in the garage (still there) they have said its a front wheel bearing and front inner track rod, but upon further inspection they found the steering rack is also in need of replacing...
Wed Apr 06 2022 6:29pm |
karlos01 Member Since: 02 Jan 2022 Location: norfolk Posts: 309 |
have you got any breakers near you that you could source one from ? |
Wed Apr 06 2022 6:31pm |
none mate, live in the arsehole of nowhere haha! im not too bothered about buying new just not at £1k if i can help it
Wed Apr 06 2022 6:34pm |
might have one close depends on area |
Wed Apr 06 2022 6:38pm |
