Home > Maintenance & Modifications > Which suspension air compressor? |
Advanced Factors Site Sponsor Member Since: 26 Apr 2013 Location: Southampton Posts: 288 |
The Hitachi factory was destroyed by a Tsunami in 2012, AMK compressors were used after that. This means that your vehicle would have been originally fittted with the Hitachi LR023964. However, if the compressor has been replaced before it may have an AMK LR078650 on it now, but maybe not.
Fri Mar 18 2022 11:30am |
rich_959 Member Since: 26 Aug 2021 Location: East Yorkshire Posts: 15 |
Thanks Matt. I'll have the cover off and check. Seems to be the best way. If it had been replaced in the past (with the newer AMK style) but not had the software update done, would it work at all? Or could that be an explanation for the occasional harsh ride at the front?
Fri Mar 18 2022 11:40am |
The compressor will work without the software update. As I recall the update does something to put less stress on the pump. Unfortunately, I don't know what happens if you don't get it updated. Paul Redding
Fri Mar 18 2022 12:34pm |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1067 |
The bumpy ride mentioned will be related to airbags and shocks on the front - nothing to do with the air compressor.
Fri Mar 18 2022 12:55pm |
Thanks guys. Yeah, I guess I've been thinking that because there are no air leaks, the suspension units are ok. But I guess the air springs could be fine, but the struts (shocks) worn out. |
Fri Mar 18 2022 4:25pm |
zenta Member Since: 22 Jan 2022 Location: Vienna Posts: 4 |
i bought my rrs third hand. compressor gives problems every now and than. i bought the repair kit for the hitachi, before checking what compressor is underneath. not smart... the compressor has been replaced by the first owner with the amk model. so i think the best thing to do is if you have the hitachi, buy the repair kit. easy fix i would guess.. 2011 RRS 3.0 TDV6 Fuji White |
Mon Apr 18 2022 5:02am |
