Home > General > Rear spoiler reverse camera
TONY173
England 2010 Range Rover Sport TDV8 Autobiography Santorini Black
I have a 2010 RRSPORT 3.6 And have managed to damage the camera when emptying it of water as the seals had corroded.
Is there an after market replacement available and from who ? I’ve tried eBay and part finder without any luck.
Can anyone help please
Post #622889 Thu Mar 17 2022 9:09pm
I don't think you will find a direct aftermarket replacement or at least have never seen one, the LR Part No. is LR031791 if that helps finding one although the number may have changed by now.
Post #622891 Thu Mar 17 2022 9:30pm
TONY173
Thanks Col, there is one on eBay with same connections but different numbers on the label attached to the camera, it’s in the states I think at a mega $286 so they aren’t cheap then
Post #622894 Thu Mar 17 2022 10:12pm
Ken 153
United Kingdom 2010 Range Rover Sport Supercharged HSE Galway Green
Item is on back order with JLR and they retail for around £285.00
Post #622895 Thu Mar 17 2022 10:31pm
If you do go for a ebay one, make sure it is not the the surround camera version they look almost identical in appearance but have 4 pins instead of 2 and are not interchangeable.
Post #622901 Thu Mar 17 2022 11:28pm
