![]() | Home > General > Rear spoiler reverse camera |
TONY173 Member Since: 19 Jan 2022 Location: Tamworth Posts: 7 ![]() ![]() ![]() |
I have a 2010 RRSPORT 3.6 And have managed to damage the camera when emptying it of water as the seals had corroded.
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5066 ![]() ![]() ![]() |
I don't think you will find a direct aftermarket replacement or at least have never seen one, the LR Part No. is LR031791 if that helps finding one although the number may have changed by now.
Thanks Col, there is one on eBay with same connections but different numbers on the label attached to the camera, it’s in the states I think at a mega $286 so they aren’t cheap then |
Ken 153 Member Since: 02 Sep 2021 Location: Sheffield Posts: 189 ![]() ![]() ![]() |
Item is on back order with JLR and they retail for around £285.00 |
If you do go for a ebay one, make sure it is not the the surround camera version they look almost identical in appearance but have 4 pins instead of 2 and are not interchangeable.
