Home > General > Jacking |
Hightimo Member Since: 08 Jan 2022 Location: Liverpool Posts: 74 |
Yes I have done this - but always disconnect the battery as the air suspension can try and self- level etc …. And with our stating the obvious make sure you get a decent axle stand underneath- they are a lot heavier than standard cars . |
Sat Mar 12 2022 6:12pm |
karlos01 Member Since: 02 Jan 2022 Location: norfolk Posts: 309 |
I'm going to disconnect the battery as changing ABS sensor
Sat Mar 12 2022 6:24pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4946 |
I always jack it at normal height anyway |
Sat Mar 12 2022 7:02pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8980 |
One raises the suspension because the wheels will stay on the ground until it's at full droop. By jacking it up, you've had the car do half of the work for you. And if you ever use the provided jack, you'll know why that's a good idea. The jack is borderline unusable. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Sat Mar 12 2022 10:17pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4971 |
Drive it up on a block of wood and stick a trolley jack under the lower suspension arm, won't matter what height the suspension is then.
Sat Mar 12 2022 10:49pm |
thanks col I'll do that because I've got a faulty ABS sensor it loosing HDC and special programs and keeps lowering the suspension |
Sun Mar 13 2022 7:40am |
I’ve jacked 00’s of rangerovers & never raised the suspension & never had a problem,just remember when you lower it all the doors have to be closed for it to self level. Andy.
Sun Mar 13 2022 8:31am |
would it make any difference as will be disconnecting the battery? |
Sun Mar 13 2022 8:52am |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1251 |
As tyrefitter, when changing the winter/summer wheels over on the driveway. I’ve never raised from the standard position. When I’m done though I do raise then lower to access to standard to settle everything. I’ve never had a problem as a consequence or I’ve been lucky. 2006 2.7 TDV6 HSE in Cairns Blue. |
Sun Mar 13 2022 1:35pm |
flydive Member Since: 16 May 2007 Location: South Posts: 1213 |
Not raising to off road does not create problems.
Sun Mar 13 2022 2:22pm |
thats all good but I can't get the suspension to raise or lower as it has lowered it self cause I had a fault with ABS sensor |
Sun Mar 13 2022 2:57pm |
