Home > General > Jacking
karlos01
Jacking
it states in the manual that the RR suspension should be raised up when jacking up the vehicle
I've got a problem where I can't get the suspension to lift
need to change a ABS sensor and need to take the tyer off
would it still be ok to jack up with suspension lowered?
Post #622733 Sat Mar 12 2022 6:59pm
Hightimo
United Kingdom 2007 Range Rover Sport TDV8 HSE Zermatt Silver
Yes I have done this - but always disconnect the battery as the air suspension can try and self- level etc …. And with our stating the obvious make sure you get a decent axle stand underneath- they are a lot heavier than standard cars .
Post #622734 Sat Mar 12 2022 7:12pm
karlos01
I'm going to disconnect the battery as changing ABS sensor
got a trolly jack and 2 axle stands as you say they a heavy lump to jack up my P38 2.5 was heavy enough
Post #622736 Sat Mar 12 2022 7:24pm
I always jack it at normal height anyway
Post #622738 Sat Mar 12 2022 8:02pm
Re: Jacking
One raises the suspension because the wheels will stay on the ground until it's at full droop. By jacking it up, you've had the car do half of the work for you. And if you ever use the provided jack, you'll know why that's a good idea. The jack is borderline unusable. 2012 SDV6 - it's missing a couple of cylinders
Post #622745 Sat Mar 12 2022 11:17pm
Drive it up on a block of wood and stick a trolley jack under the lower suspension arm, won't matter what height the suspension is then.
Post #622746 Sat Mar 12 2022 11:49pm
karlos01
thanks col I'll do that because I've got a faulty ABS sensor it loosing HDC and special programs and keeps lowering the suspension
Post #622751 Sun Mar 13 2022 8:40am
Tyrefitter
I’ve jacked 00’s of rangerovers & never raised the suspension & never had a problem,just remember when you lower it all the doors have to be closed for it to self level. Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #622754 Sun Mar 13 2022 9:31am
karlos01
would it make any difference as will be disconnecting the battery?
Post #622758 Sun Mar 13 2022 9:52am
Stevepd
As tyrefitter, when changing the winter/summer wheels over on the driveway. I’ve never raised from the standard position. When I’m done though I do raise then lower to access to standard to settle everything. I’ve never had a problem as a consequence or I’ve been lucky. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #622769 Sun Mar 13 2022 2:35pm
flydive
Not raising to off road does not create problems.
You just work more than necessary, as explained by RRSTDV8 '08 RRS TDV8
Post #622771 Sun Mar 13 2022 3:22pm
karlos01
thats all good but I can't get the suspension to raise or lower as it has lowered it self cause I had a fault with ABS sensor
Post #622772 Sun Mar 13 2022 3:57pm
