Home > Maintenance & Modifications > Spark Plugs for L494 SCV8
People, talk to me about sparkies: I have the 7yr service coming up, and maybe I should splurge on fancy sparkies due to the VAP remap?
On another forum, I saw that the specified NGK plugs are factory set (new in the box) at 0.026", but NGK themselves recommend 0.032".
thanks --
Post #622673 Thu Mar 10 2022 9:40am
Manual say's 1.0 mm (0.03937 in) I do have a new set here somewhere of LR032080 which are the ILKAR7C10 will check what they are gapped at from the factory if I can find them.
Post #622675 Thu Mar 10 2022 11:31am
thanks Col Thumbs Up --
Post #622678 Thu Mar 10 2022 12:30pm
Advanced Factors
Site Sponsor
Looks like 1mm gap to me. Sorry for using an uncalibrated 30cm ruler.
 Paul Redding
+44 (0)23 8052 2776
paul@advancedfactors.co.uk
Post #622680 Thu Mar 10 2022 1:23pm
All good, Col, thanks a lot.
I can't seem to find the NGK locally, might have to import them. --
Post #622681 Thu Mar 10 2022 1:35pm
Just checked the set I have here, all gapped at 0.038" from the factory. Also remember seeing this so maybe genuine factory supplied one's are pre-set from factory. S/C belt recommended change at 7 years as well if I remember right, although did Aux belt as well when did mine as you're half way there.
Post #622695 Fri Mar 11 2022 12:23am
