Home > General > Do I really need to get another service before my MOT? |
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 899 |
MOT & service are not related. Well they are if you bought it new as the car would be serviced yearly & the Mot would begin on the 3rd anniversary, but there are lots of reasons for them to be out of sync ie car traded in & seller puts a new service or Mot on it. As yours was serviced in November it does not need another until November unless your racking up the miles. From memory (may be wrong, service is every 12 months or 15000 miles, whatever comes first). You get a message on your facia which tells you your service is due in xx miles. Though it counts down rather quickly, so its really done on time basis.
Sun Feb 27 2022 1:25pm |
Josh95 Member Since: 08 Dec 2021 Location: Belfast Posts: 49 |
Good to know, thanks! The MOT wasn’t due until March - I got the car November. So I guess he didn’t bother. |
Mon Feb 28 2022 3:24pm |
Mon Feb 28 2022 5:03pm |
Ask him or/and check with your Vin that the service has been recorded on Land Rover database now that everything is digital or you may find when selling, it has a missing service. If he has not access to the database get the manual service paperwork & keep it safe in order to prove it has been serviced & as riverblanche said, what Full service was done. Range Rover Sport (gone): Mercedes S63 AMG Coupe: 992 Porsche Carrera 4S: Range Rover Fifty P400e |
Mon Feb 28 2022 6:50pm |
So I got in contact - turns out it has only had an oil service and the brake pads replaced. What else should I be asking the Indy to do next week? Was originally supposed to get the gearbox serviced but may need to put this on the back burner for a bit. |
Tue Mar 01 2022 3:24pm |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1251 |
Josh I’d consider the oil in the diffs and transfer box are replaced. Also the pollen and fuel filter. It may seem a lot but you’ll know where you stand regards the maintenance. Sometimes the cars get a tarnished reputation but these cars are lovely and comfortable, but you must be prepared to invest in maintenance. Good luck. 2006 2.7 TDV6 HSE in Cairns Blue. |
Tue Mar 01 2022 4:31pm |
Your Indy should be able to guide you on what needs done depending on mileage. Would not bother getting the oil done again. Ask him to give it a good check over for piece of mind Range Rover Sport (gone): Mercedes S63 AMG Coupe: 992 Porsche Carrera 4S: Range Rover Fifty P400e |
Tue Mar 01 2022 4:41pm |
Wed Mar 02 2022 12:08pm |
If you’re talking about the timing belt - it was done two years ago. |
Wed Mar 02 2022 5:53pm |
