![]() | Home > General > Noisy heater |
BJH1959 Member Since: 25 Mar 2017 Location: Paredes de Coura, Portugal Posts: 410 ![]() ![]() ![]() |
When I turn on the heater I’ve recently noticed it makes more noise than previously inside the cabin. Whether it’s on warm or cool it sounds louder than usual (constantly) as if it is working harder. It is working efficiently and responsively; temperature gauge is normal.
Have you changed the pollen air filter ?
Andy... Not since the last service, and it will be done on the next in a couple of weeks time. Would changing it cause the system to make more noise, or, is it a case of it may need changing? Barrie.
I thought if it had not been changed for many years, it could cause noise.
With the pollen filter removed, are you able to see the fan or photograph it for inspection. Perhaps a squirt of wd40 if you’re able to see/aim? 2006 2.7 TDV6 HSE in Cairns Blue. |
Thanks. Will give this a go. Barrie.
Perhaps it's the blower motor bearings getting worn and noisy.
DirtBuddha Member Since: 12 Jan 2022 Location: West Sussex Posts: 28 ![]() ![]() ![]() |
My new (to me) 2010 RRS also has an incredibly noisy fan… was quite surprised at this having just changed from a beautifully silent D3. |
Thanks for your thoughts everyone. If I find the cause I will post outcome. |
Update: The noise just stopped on its own after time. I did nothing more to explore but no issues at all. Barrie.
