Home > General > Noisy heater
BJH1959
Portugal 2005 Range Rover Sport TDV6 HSE Cairns Blue
Noisy heater
When I turn on the heater I’ve recently noticed it makes more noise than previously inside the cabin. Whether it’s on warm or cool it sounds louder than usual (constantly) as if it is working harder. It is working efficiently and responsively; temperature gauge is normal.
Outside temperatures are not extreme here and are currently around 22 degrees during the day and -2 at night.
I just wondered if this could be an indication of something? It’s going in for servicing soon.
(2005 TDV6 2.7, 90k miles.). Barrie.
2017-Jan 2024: 2005 RRS 2.7TDV6. Best car I ever had - until now!
Current: 2018 Ford Ranger Wildtrak 3.2
Post #622222 Fri Feb 25 2022 9:03am
kas982
United Kingdom 2005 Range Rover Sport Supercharged Bonatti Grey
maybe you were lucky before, the heater fan ( past the 1st setting ) are noisy/louder than other vehicles in this bracket.
Post #622238 Fri Feb 25 2022 5:18pm
Have you changed the pollen air filter ?
Behind the glovebox
Post #622242 Fri Feb 25 2022 7:33pm
BJH1959
Andy... Not since the last service, and it will be done on the next in a couple of weeks time. Would changing it cause the system to make more noise, or, is it a case of it may need changing? Barrie.
Post #622243 Fri Feb 25 2022 7:41pm
I thought if it had not been changed for many years, it could cause noise.
But if you service regurarly then probably not that.
Removing the filter and running the fan briefly may help you understand where the noise is coming from
Post #622256 Sat Feb 26 2022 11:30am
Stevepd
With the pollen filter removed, are you able to see the fan or photograph it for inspection. Perhaps a squirt of wd40 if you’re able to see/aim? 2006 2.7 TDV6 HSE in Cairns Blue.
Post #622260 Sat Feb 26 2022 1:30pm
BJH1959
Thanks. Will give this a go. Barrie.
Post #622268 Sat Feb 26 2022 8:00pm
Perhaps it's the blower motor bearings getting worn and noisy.
Post #622289 Sun Feb 27 2022 8:59pm
DirtBuddha
England 2010 Range Rover Sport TDV8 HSE Galway Green
My new (to me) 2010 RRS also has an incredibly noisy fan… was quite surprised at this having just changed from a beautifully silent D3.
Post #622290 Sun Feb 27 2022 9:02pm
BJH1959
Thanks for your thoughts everyone. If I find the cause I will post outcome. Thumbs Up Barrie.
Post #622296 Mon Feb 28 2022 7:22am
BJH1959
Update: The noise just stopped on its own after time. I did nothing more to explore but no issues at all. Barrie.
Post #625279 Fri Jul 08 2022 7:34am
