Home > Faults & Fixes > 2007 RRS 2.7 none starter |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4971 |
Have they tried refitting the new cam sensor again? might prove something not really sure what though but can't do any harm.
Tue Feb 15 2022 7:40am |
Matt_82 Member Since: 14 Feb 2022 Location: Blackpool Posts: 14 |
Hi Col. Ive just had it confirmed, although the old cam sensor appeared ok, they kept the replacement cam sensor in the car. Any idea of the failure rate of cam sensors? |
Tue Feb 15 2022 9:05am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4946 |
They are reliable. So suspect wiring or ecu |
Tue Feb 15 2022 9:25am |
Do you know what sort of reluctor is used for the cam sensor? |
Wed Feb 16 2022 10:00pm |
I think it just looks for metal or a gap (air)
Wed Feb 16 2022 10:22pm |
The manual is a little confusing as it doesn't directly show on what it actually picks the signal up from.
Thu Feb 17 2022 12:04am |
UPDATE
Mon Feb 28 2022 3:47pm |
So....
Tue Mar 15 2022 10:51am |
8.5v is too low
Tue Mar 15 2022 12:10pm |
A brand new battery, although the engine is turning over a lot better, is still not firing! |
Tue Mar 15 2022 6:13pm |
Check the CCA value of the battery, on the label.
Tue Mar 15 2022 6:46pm |
We used a brand new 100amp hour 900 cold crank |
Tue Mar 15 2022 7:41pm |
Finally its back on the road.
Wed Apr 13 2022 1:40pm |
RR-Panda Member Since: 01 Aug 2023 Location: Gold Coast Posts: 6 |
Tanks so much for putting in your fix - so many ask all the questions but when they finally fix it they don't post it.
Thu Aug 03 2023 2:55am |
