![]() | Home > Faults & Fixes > 2007 RRS 2.7 none starter |
Have they tried refitting the new cam sensor again? might prove something not really sure what though but can't do any harm.
Matt_82 Member Since: 14 Feb 2022 Location: Blackpool Posts: 14 ![]() ![]() ![]() |
Hi Col. Ive just had it confirmed, although the old cam sensor appeared ok, they kept the replacement cam sensor in the car. Any idea of the failure rate of cam sensors? |
They are reliable. So suspect wiring or ecu |
Do you know what sort of reluctor is used for the cam sensor? |
I think it just looks for metal or a gap (air)
The manual is a little confusing as it doesn't directly show on what it actually picks the signal up from.
UPDATE
So....
8.5v is too low
A brand new battery, although the engine is turning over a lot better, is still not firing! |
Check the CCA value of the battery, on the label.
We used a brand new 100amp hour 900 cold crank |
Finally its back on the road.
RR-Panda Member Since: 01 Aug 2023 Location: Gold Coast Posts: 6 ![]() ![]() ![]() |
Tanks so much for putting in your fix - so many ask all the questions but when they finally fix it they don't post it.
