![]() | Home > Technical > Rear view camera problem - L494 2017 |
GroosterUK Member Since: 02 Feb 2022 Location: Preston Posts: 17 ![]() ![]() |
Still needing advice if anybody can help.
Red Arrow Member Since: 06 Jun 2017 Location: Scotland Posts: 591 ![]() ![]() |
Try gently drying / heating the camera off with a hairdryer |
Its definitely worth a try tonight with the hairdryer. Im pretty sure its dried up now though. The leaks been sorted for a few weeks now.
teldec Member Since: 29 Dec 2019 Location: essex Posts: 80 ![]() ![]() |
Once you remove the boot trim you will see the camera, it is easy enough to swap out, they suffer from water ingress through the clips so make sure you put some clear silicone on the clips when you fit the new one |
Thanks, just need to source a cheap camera unit now. The one on mine has the camera and another sensor. In one unit. There’s a couple of used ones on eBay. Does anybody know what the other sensor is for?
best to take it out and get the exact part number, mine was impossible to find as it has the deployable tow bar pack. loads on ebay but i got a new one from duckworth site sponsors for 226.91 |
