Home > Technical > warning lights |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4985 |
fairly normal for a RR
Wed Feb 02 2022 8:24pm |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1540 |
And I would use a quality replacement bulb for the brake light. Also consider replacing the brake light switch Robin
Wed Feb 02 2022 8:29pm |
karlos01 Member Since: 02 Jan 2022 Location: norfolk Posts: 309 |
thanks guys I've got some bulbs to replace the faulty ones will be first job when I'm back from work I did say would be something silly but you know women they panic
Thu Feb 03 2022 6:28am |
Thu Feb 03 2022 5:53pm |
Scrumpy Member Since: 11 Nov 2016 Location: Surrey Posts: 567 |
I had this on mine some time ago and if I remember correctly it was fixed by replacing the battery.
Thu Feb 03 2022 7:48pm |
was thinking about putting the battery on charge and see if that would help
Thu Feb 03 2022 7:56pm |
I second this as a route to follow if for no other reason than it’s free to do, assuming you’ve got a multimeter. But if that shows no issues then perhaps a visit to a local tame indie (if available) for the faults to be read would be better than spending to long or too much on replacing bits that may be don’t need replacing Robin 2008 Range Rover Sport TDV8 Gone: Jaguar S-Type V8 4.2 Sport MGZTT 190 2.5 |
Fri Feb 04 2022 11:12am |
just quick update charged the battery had diagnostic put on got all the lights off apart from adaptive front lighting system this stays aluminated then after a drive down the road all the other lights come back on |
Sun Feb 06 2022 2:59pm |
think I've cured the problem it was the adaptive lights took head lights out both connectors was covered in crud clean with rag and some connection cleaner put back together and now all the lights are off and the headlamps are moving again |
Sun Feb 06 2022 3:45pm |
Nice one! Don’t even get me started on what happens if your adaptive headlights give up the ghost😂 Robin
Sun Feb 06 2022 8:46pm |
I was pleasantly surprised at how easy it was to remove the headlamps no nuts or screws just sliding lock pins
Mon Feb 07 2022 6:11am |
Mon Feb 07 2022 6:41pm |
fixed it finally after been to body shop for some work
Sun Mar 13 2022 5:49pm |
