![]() | Home > Technical > warning lights |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5040 ![]() ![]() ![]() |
fairly normal for a RR |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1543 ![]() ![]() ![]() |
And I would use a quality replacement bulb for the brake light. Also consider replacing the brake light switch Robin
karlos01 Member Since: 02 Jan 2022 Location: norfolk Posts: 309 ![]() ![]() ![]() |
thanks guys I've got some bulbs to replace the faulty ones will be first job when I'm back from work I did say would be something silly but you know women they panic
Scrumpy Member Since: 11 Nov 2016 Location: Surrey Posts: 567 ![]() ![]() |
I had this on mine some time ago and if I remember correctly it was fixed by replacing the battery.
was thinking about putting the battery on charge and see if that would help
I second this as a route to follow if for no other reason than it’s free to do, assuming you’ve got a multimeter. But if that shows no issues then perhaps a visit to a local tame indie (if available) for the faults to be read would be better than spending to long or too much on replacing bits that may be don’t need replacing Robin 2008 Range Rover Sport TDV8 Gone: Jaguar S-Type V8 4.2 Sport MGZTT 190 2.5 |
just quick update charged the battery had diagnostic put on got all the lights off apart from adaptive front lighting system this stays aluminated then after a drive down the road all the other lights come back on |
think I've cured the problem it was the adaptive lights took head lights out both connectors was covered in crud clean with rag and some connection cleaner put back together and now all the lights are off and the headlamps are moving again |
Nice one! Don’t even get me started on what happens if your adaptive headlights give up the ghost😂 Robin
I was pleasantly surprised at how easy it was to remove the headlamps no nuts or screws just sliding lock pins
fixed it finally after been to body shop for some work
