Home > General > wind deflectors
karlos01
wind deflectors
was thinking about putting wind deflectors on our RRS just wondering what people's go to brands are I've been looking at theses
Post #621401 Sun Jan 30 2022 10:18am
Dave B
Mine has similar when I bought the car, considering the glass was double glazed I thought the wind noise was unacceptable.
Took them off and once the rubbers had gone back to the shape they were supposed to be, it's a lot quieter.
Dave 2010 3.6 TDV8 HSE (Gone)
2011 Discovery 4 Commercial SDV6 (Gone)
1980 OBLIC 4.0ltr Range Rover (went a long time ago)
Post #621404 Sun Jan 30 2022 11:03am
karlos01
so you're taken yours off?
it not so much when they shut it when they open and you clean the windscreen the water comes in through the window just thought they would stop it
Post #621405 Sun Jan 30 2022 11:14am
Dave B
That is a problem I know, I just keep the windows closed.
Post #621406 Sun Jan 30 2022 11:26am
karlos01
yeah that's why was thinking of fitting the wind deflectors
Post #621408 Sun Jan 30 2022 12:26pm
NoExpert
Or adjust the jets so they don’t spray so far to the sides. My side windows never get washer fluid on them. I also enabled spray on up stroke so that may help as well. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #621416 Sun Jan 30 2022 4:40pm
karlos01
thats true bit still be handy when it raining as I normally have the window a bit when driving
Post #621417 Sun Jan 30 2022 5:40pm
NoExpert
Well, it sounds like you’re pretty determined, which is all good and well.
Clips - possible wind noise, but securely attached.
Stick on - no/less wind noise, may fly off and hit somebody/another car requiring you to flee the scene.
Neither - may get wet with the window slightly down, no wind noise, nothing flying off and killing innocent children.
Another silly consideration, they will also make your A pillar blind spot larger. But, they might keep that precipitation and windshield washer fluid out, maybe, if you roll your windows down just right. Granny in a wheelchair hiding in your A pillar blind spot while making a turn? Well, the old cow deserves to be run over anyway for being too lazy to walk and holding up traffic, right?
Anyway, the only real opinion that matters is yours. Buy off Amazon, if you’re not happy with them send them back. That’s the real answer. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #621420 Sun Jan 30 2022 8:21pm
HMV
Finland 2011 Range Rover Sport 3.0 TDV6 HSE Bali Blue
Hi
I have Heko deflectors fitted. I like style and quality is ok...
https://e-heko.com
HMV
Post #621421 Sun Jan 30 2022 8:27pm
Out of curiosity I fitted a set, absolutely useless, lot of wind noise and downright ugly to boot, they got binned pretty quick, and that was genuine L/R one's.
Post #621425 Sun Jan 30 2022 9:07pm
karlos01
thanks for all the replies chaps
I did factor about blind spots being more I'm ok with that as use to have them fitted to HGV its the missus who will need to get use to them if I fit them got a few bits to sort out on the RR before I get around to fitting the deflectors
Post #621433 Mon Jan 31 2022 7:35am
