Home > Technical > Codes |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4985 |
dO YOU HAVE AFS lights where the beam moves ? |
Fri Jan 28 2022 4:18pm |
joboco Member Since: 13 Sep 2021 Location: Scotland Posts: 24 |
Fri Jan 28 2022 4:49pm |
So you have an afs warning in the dash or orange light stuck on ?
Fri Jan 28 2022 6:28pm |
No warning light on the dash, of any kind. I'll check the headlights tomorrow as it's 60 mph winds and rain out just now. Just checked and no light dancing on auto or manual left or right. |
Fri Jan 28 2022 7:04pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5001 |
Fri Jan 28 2022 8:26pm |
Thank you, I'll check that ASAP. Will the gap lld be the correct diagnostic for this? |
Fri Jan 28 2022 8:37pm |
That is L/R's description of the fault code, if the Gap IID gave you that code it seems to me to be the most logical place to start, rather than "well it could be this, could be that" however I'm sure codes can be incorrect sometimes.
Fri Jan 28 2022 8:49pm |
Cheers Col much appreciated. |
Fri Jan 28 2022 8:51pm |
Thanks col.
Fri Jan 28 2022 10:21pm |
What do you mean, you where guessing down the wrong route??? |
Sat Jan 29 2022 5:40am |
I thought it could be an afs problem.
Sat Jan 29 2022 8:09am |
