Home > Technical > Replacing Main Engine Wiring Loom L320 2006 range rover spor |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4939 |
Are you driving it ?
Thu Jan 20 2022 7:44pm |
Nveeate Member Since: 10 Aug 2021 Location: Scotland Posts: 28 |
Have you tried an automotive electrician? They may be able to just replace the damaged sections... |
Thu Jan 20 2022 8:04pm |
Simon_CSK Member Since: 21 Dec 2020 Location: East Ayrshire Posts: 70 |
I am in the process of finishing that on an Insurance write off that I bought in September.
Thu Jan 20 2022 8:20pm |
Lucksranout Member Since: 20 Jan 2022 Location: Devon Posts: 3 |
Hi thanks you all for your reply's, as it's a non runner andy, I'm currently awaiting it's recovery tomorrow, so when it arrives back from the garage from the initial diagnostics I will take some pictures of where it is burnt.
Fri Jan 21 2022 4:20pm |
The first thing I need to know is the extent of the loom being replaced.
Fri Jan 21 2022 7:22pm |
Devon Z Member Since: 22 Sep 2019 Location: Brixham, Devon Posts: 314 |
As a former auto electrician from what youβve described I can imagine the damage to be very localised so I would of thought a repair would be possible or if the damaged section is a spur cut it from a second hand loom and slice it in. Steve
Fri Jan 21 2022 7:35pm |
Fri Jan 21 2022 8:07pm |
I think you need more than a wiring loom |
Fri Jan 21 2022 8:09pm |
It is more or less back together. Current cars
Fri Jan 21 2022 8:50pm |
Holy cπ¬π¬p!! Thatβll be a new loom, at times like this Iβm glade I only have six cylinders π Steve
Sat Jan 22 2022 12:47pm |
New Loom
Sat Jan 22 2022 1:36pm |
